Carb icing.
bushman
Carb icing.
Mon Feb 22, 2010 9:02 am » Post: #1 » Download Post
Does anyone's bike suffer it?I was out yesterday,a right cold day,and had some running problems,nothing obviously wrong,ambient was 1c.
wb
Mon Feb 22, 2010 8:55 pm » Post: #2 » Download Post
Not sure if it answers your question, but If I ride my TZR 3MA in zero-ish temperatures it ices like a good 'un (carb heating circuit is removed for simplicity and access - and the carbs being out front rather than tucked behind the cyls probably doesn't help either... ) Feels like the choke is on and it affects running most at low revs as the pilot air intakes frost up making it run massivley rich on the pilots.
If your rough running goes away as soon as the ambient temp warms up a bit it's likely to be icing. If your carb heating circuit is still fitted (assuming the NSR runs one - I cant remember?) it would be very unlikely to strike I'd think - unless there's a blockage in the circuit.
Still smoking...
dunkenb
1989 Honda NSR250 MC18
Mon Feb 22, 2010 10:28 pm » Post: #3 » Download Post
had a tzr 125 rr 4dl that iced up on a regular basis!! warming up fully before riding helped.
