I've read the instructions in the tuning section a million times but I'm still confused as to where the X piece goes. The side with the jet left open to air. The 2 smaller joints go to the carb's, and the last joint goes to the pipe adjoining the Y joint.
Side left open to air - easy for Craig to figure out.
2 smaller joints - go to carbs. Ok..found those hoses on the left sides of the carbs.
Last joint - "pipe adjoining the Y joint" Here's where I'm stuck. Does this hose go INTO the Y joint or into the solenoid next to it?
I'm just confused because it appears that one thing will be left either open or flopping around. If the pic was larger in the tuning section it would be great but I just can't see the details in it I need.
Thanks!
