rust on the inside of the tank
nsrjb
Thu May 27, 2010 6:45 pm » Post: #1 » Download Post
i was just wondering what is the best approach to sorting out the rust problem on the inside of a fuel tank?.
is there special cleaners products etc?
coolhand91
    Send private message View user's profile Yahoo Messenger
Thu May 27, 2010 7:38 pm » Post: #2 » Download Post
Haven't used this stuff personally, but know quite a few people with good results from it - http://www.kreemproducts.net/c-3-fuel-tank-liner.aspx
First you remove/dissolve the rust, then coat the inside of the tank with the resin compound.
dld
Wed Jun 02, 2010 1:48 am » Post: #3 » Download Post
i've been debating how to solve this problem as well.
the Kreem product looks like a possible solution. i've also heard of inserting bits and bolts inside the tank, with diluted acid/water, agitating the tank and rinsing it out. then coating it with a similar Kreem product.
http://www.motorcycleanchor.com/motorcycle/how_to/mc_tankrust.html
MC28 sp
nsrboy
Wed Jun 02, 2010 2:13 am » Post: #4 » Download Post
i am also about to tackle this i have some form of liner in there atm but is just peeling off. Will post up the way i use
bandit_7
Wed Jun 02, 2010 10:20 am » Post: #5 » Download Post
You could try this.
http://www.kbs-coatings.com.au/KBS-MotorCycle-Tank-Sealer-Kit_p_13.html
Bandit7
