The rebuild begins!
blue_landscaping
The rebuild begins!
Tue Jul 20, 2010 5:01 am » Post: #1 » Download Post
So hey, though I would start a thread for my 28 rebuild, because no doubt I'll be fumbling along looking for advice (despite having studied up on all the online info) and also because I wouldn't mind having a record of my activities (for posterity). Just looking to get the track bike reliable and back on the track.
So the rebuild has begun because my bike won't energise (mc28 dash did light up) the clip that holds the card is broken and it won’t make the click, test the servos or kick.
I have (sourced previously) a 21 loom; stator(??) and clocks which I have plug by plug swapped over while taking off the old 28 loom. (I think this worked out ok) however I can’t tell if the bike is energising now or not.
Is there a way to do this??
It's been sitting for a while and I don't know if it won't kick because of sitting or because the loom is well cactus!
Having grabbed a copy of the 21 wiring diagram and having grabbed a multi meter from my olds place, I am about to go through each connection and check.
One question, is what exactly should I be setting the multi meter too and is it just a matter of putting one probe on one end the other on the other and making sure (the needle moves…I mean) there is connection?? (any help would be greatly appreciated!)
I was hoping to be able to kick it over with the old loom, so I could run (last little squirt to keep me motivated) it up the road throw it on a dyno, so I can see what power its putting out at the minute and determine what sort of gains I get, may swap back looms and see if I can’t trouble shoot. (would be really interesting) Despite I’m sure testing the new loom would be heaps better upstairs warm sitting down with a beer in close reach!
Anyway I’ll keep posted of progress!
MC28 Track Bike
01' Honda VTR 250 (previously owned)
05' Suzuki Gsx-R 600 (road bike)
bushman
Tue Jul 20, 2010 11:39 am » Post: #2 » Download Post
If you are checking for continuity on the loom,set the meter to the ohms setting,omega symbol,touch the probes together to see the needle travells fully across the range first.
blue_landscaping
Wed Aug 18, 2010 1:29 am » Post: #3 » Download Post
Hey, thanks for the heads up re. Continuity Testing.
So yeah swapped back looms, and the bike is energising, but still no spark (top cylinder at least).
Tested the other loom and found a few wires don't seem to have a connection, so wondering if anyone might be able to suggest a decent auto electrician around the Northside Brisbane (Gebung) area?
Also, about to find info on the coil (assuming this is why I'm not getting spark) any suggestions??
Cheers, making some very slow progress.
MC28 Track Bike
nsrdownunder
1993 Honda nsr 250 mc21 sp
Wed Aug 18, 2010 5:23 am » Post: #4 » Download Post
Have you tried to swap coils around and see if the miss switches cylinders ?
You may have a burnt out cdi in the pgm there is one for each cylinder ?
blue_landscaping
Thu Aug 19, 2010 6:31 am » Post: #5 » Download Post
Not so much a miss in the top cylinder as much as the thing doesn't run or kick over.
I'm getting totally frustrated and am not real certain as to what to do next.
I guess I should start asking some dumb arse questions.
How is it that I can begin to trouble shoot?
As far as I can see it the power comes battery to PGM to coil to spark plug.
Am I missing something?
Probably...
MC28 Track Bike
nsrdownunder
Thu Aug 19, 2010 6:43 am » Post: #6 » Download Post
The power to run the bike is from the stator . The stator has the timming on it through the pgm to the coils . Try a lend a working PGM there are a couple of blokes in brisbane with NSR`s . I think yours is a good chance of being cactus.
Glen
Thu Aug 19, 2010 8:03 am » Post: #7 » Download Post
I have about 6 PGM's, you're more than welcome to try them.. I'm on the nth side also..
pm me if you're interested..
Paranoia about failure will ensure nothing but failure to ever reach potential.
MC18 Race bike project..
MC21 Race bike..
