WANTED MC21 front wheel
cangus
Fri Aug 20, 2010 12:01 pm » Post: #1 » Download Post
want to buy front wheel for MC21. Located in the states.
MC21R9N track
MC18R2J track
CBR954
CR250
cgallant
2001 Honda RS250
Fri Aug 20, 2010 1:01 pm » Post: #2 » Download Post
I actually have an MC21 R that I will be pulling apart and parting out. can start this weekend and get the rims pulled. take some pics and send you some pics later on this weekend.
Do you need brake discs, spacers, etc..?
cangus
Fri Aug 20, 2010 1:13 pm » Post: #3 » Download Post
i only need the wheel. Mine has a bend in the rim. It's a little more than i am comfortable with. I have tyga aluminum spacers and new bearings and the old disks are fine. how much?
MC21R9N track
MC18R2J track
CBR954
CR250
cangus
Fri Aug 20, 2010 3:42 pm » Post: #4 » Download Post
are you selling the motor or any motor components?
MC21R9N track
MC18R2J track
CBR954
CR250
cgallant
2001 Honda RS250
Sat Aug 21, 2010 1:50 am » Post: #5 » Download Post
I am going to be tearing the entire bike down and cleaning up what looks useable and selling those parts.
The engine is an unknown at this point (top end and crank). Most likely will pull the cylinders off to at least get an idea about the barrels/heads and crank. Clean up as much as I can and sell it as whole as possible (if crank and barrels/etc look good as a unit, otherwise tear it all down and sell cases/barrels/etc..)
currently I am pulling parts off, cleaning then up, bagging components and will put up a list of all I have.
Will work on getting the front rim off, get the tire taken off, clean up the rim and get you some pics hopefully by Sunday evening. We can work on price at that point.
cgallant
2001 Honda RS250
Sun Aug 22, 2010 4:00 pm » Post: #6 » Download Post
OKay,
got the front rim pulled and cleaned up a little. Removed the disc's, but didn't make it to the shop yesterday to pull the tire (will remove this prior to shipping).
Here are some pics. Rim is straigh, with a small section on one side of a little curb rash (rim/lip are still straight). Would recommend replacing bearings/seals as they are an unknown to me. I have always had luck going to any bearing supply store with the part numbers found on the side of the bearings. No need to order from Honda and overpay and wait for ever to get them. Seals are standard honda seals.
Shot me your email address and I can send you higher res pics if you want them.
Charles Gallant
