NSR125 coils on NSR250?
Harryredchow
Wed Oct 13, 2010 9:12 pm » Post: #1 » Download Post
Anybody know if this is a straight swap? The seem to have the same fittings. Pattern NSR125 coils are about £12 each.
Thanks!
Thu Oct 14, 2010 8:53 pm » Post: #2 » Download Post
No idea, sounds like you're volunteering to buy one and compare them!?
Harryredchow
Fri Oct 15, 2010 6:15 am » Post: #3 » Download Post
That was going to be my next post Laughing I think one of mine is failing. Have a dyno session booked on Saturday so will check it out then. Racer38 kindly lent me a coil, which I will take to the dyno to try and diagnose the problem. If it needs a new coil, I will buy a coupe of the NSR125 coils and give it a go.
Fri Oct 15, 2010 5:40 pm » Post: #4 » Download Post
Before you connect it up, do a quick check to make sure the primary and secondary resistance readings are the same or you may fry something...
Harryredchow
Fri Oct 15, 2010 6:33 pm » Post: #5 » Download Post
WIll do. Thanks Dave.
