one cylinder running hot
baron580
Thu Nov 18, 2010 11:08 pm » Post: #1 » Download Post
Does anybody know wht the front cylinder would run hotter that the rear one?
I fitted DFR pipes, jetting left as standard for now. In fact DFR emailed me and said that there was no need to re-jet as long as the air box and air filter was standard and unmodified.
Anyway, started the bike and left it warm up for about 4 mins. I then noticed the exhaust pipe on the front cylinder was alot hotter than the one on the rear. Also the exhaust gas emmiting from the right exhaust pipe(front cylinder) was hotter than the left pipe(rear cylinder).
Just wondering if this is normal or is there something up.
dunkenb
1989 Honda NSR250 MC18
Fri Nov 19, 2010 4:39 pm » Post: #2 » Download Post
the cold ones not sparking, try a new spark plug and check the carb for that cylinder , could be leaky float valve or crap in it. and check the coil etc for a good spark.
Chester362
Fri Nov 19, 2010 9:02 pm » Post: #3 » Download Post
I always drag this one out when reading of these symptoms.
First thing I would check would be the balance of the carbs. Especially if everything seems okay when you rev the engine, ie, the cooler cylinder chimes in and the exhaust gas warms up just by cracking the throttle open slightly off idle. Also if it revs cleanly when blipping the throttle, then it could just be that the throttle slides are slightly out of synchronisation. This can cause the problem you are seeing when the bike sits on idle.
The adjuster is the spring loaded screw that sits inbetween the carbs on the throttle mechanism.
I used a temporary tank to let me get at it to set them up. I also ended up doing it by ear as I got fed up trying to do it by eye!
The idea is to try and get the slides to open together at the same time.
You may want to clean/blow out the pilot jets, etc while you are at it anyway. Being as you are already in there.
cangus
Mon Nov 22, 2010 5:34 pm » Post: #4 » Download Post
i had one cylinder not firing at idle due to a blocked pilot jet.
baron580
Mon Nov 22, 2010 9:21 pm » Post: #5 » Download Post
OK, Cheers guys. Will have a look at what you said.
Thanks
