I run 24 psi rear and 28 psi front. Track or street. I replace tires after 2 track days. Some will say higher, but the lower temps let the tire run a little warmer, hence stickier.
It all depends on the tires, ambient temps and type of riding.
Best bet is to go with the manufactures recommendations usually posted on the side wall of the tire.
I will say that some of the michelin pilot pro's are much lower then say Dunlop or Bridgestone for racing/track day conditions. But again, go by manufacturers recomendations.
