m18 11 wire splice info request
haydenvn
Sun Apr 16, 2017 6:47 pm » Post: #1 » Download Post
Hi
I am picking up a japan import to uk in the next few weeks that i believe is standard. I have read the details of returning to full power with the wire splice but does this need backing up with carb rejetting.?
Mon Apr 17, 2017 12:21 am » Post: #2 » Download Post
We recommend with every mod, no matter how small, that the jetting is always re-assessed. In fact, before you even start fiddling, it would be wise to check the jetting against the stock chart in the Tech section.
There are no standard full-power settings, as no NSR250 ever went to market unrestricted, so please don't ask for any! Wink
I will add though that the ignition isn't the only restriction. You will need to open up the airbox a little too, to help it breath. Don't just hack a huge hole in it though, as that will do more harm than good on an otherwise standard motor.
haydenvn
Mon Apr 17, 2017 7:53 am » Post: #3 » Download Post
thanks for info.h
