Fooling the PGM3 to run just 1 map
drunkn munky
Tue Jun 06, 2017 8:39 am » Post: #1 » Download Post
If using a non GPS motor can the PGM3 be fooled into thinking its always in one gear by earthing out the corresponding gps wire?
drunkn munky
Fri Jun 09, 2017 6:46 am » Post: #2 » Download Post
Is this a really obvious question or does genuinely nobody know?
toddlamp
Sun Jun 11, 2017 1:11 am » Post: #3 » Download Post
You can splice the wires for all the gears i to one. It is an alternative to delimiting. I know it can be donw but i have no idea which wires to work with.
Mon Jun 12, 2017 11:26 am » Post: #4 » Download Post
It's not an alternative to delimiting.
drunkn munky
Mon Jun 12, 2017 2:57 pm » Post: #5 » Download Post
So is it as simple as earthing the 3rd gear wire for example?
Im using a 18 motor in a 21 so have no GPS
