Bike - MC28 NSR 250SE
Mods - Tyga pipes, UNI air filter
Jetting - Nothing was changed since it was running perfect and now
Considerations - I just recently rebuilt the top and bottom ends of the motor, but please read on: (1) Bike had the same issues before the motor build, (2) Leak down test was strong at 6psi for 10 min, (3) I can get the bike running perfectly with carbs from a friend's MC28
After 2 years of good performance, my NSR250 (PGM4) has recently been running rough, which I think I've isolated to the carbs.
Symptom 1-
Idle, 1st and 2nd gear pull great. Climbs the power band smoothly with no flat spots. However, once you get into 3rd, the entire bike goes flat, like there's no gas. In this case, I can either keep the throttle open, in which it'll stay flat and feel like it's going to die for a few seconds before suddenly having a surge of power, or I can pull in the clutch and rev it freely. If I come to a stop (ie stop sign) after doing either of the above, it will idle, but once I start to go again, the bike dies like there's no gas. After stalling, it won't start on the first kick, but will always start on the second kick.
Symptom 2-
Again, the bike will pull hard in 1st and 2nd, but if instead of shifting, I actually slam on the brake and come to a stop, the bike again (not moving) will idle, but once I start to go again, it dies out like no gas. First kick doesn't start, but second kick fires right up.
Clues 1-
1. Cleaned the hell out of my old carbs, every jet and every passage allows fluid through
2. Set the floats to 13mm per FSM
3. Cleaned the float needles and valves
4. Synced left and right carbs together
Clues 2- This is where it gets interesting
After running in circles with my own carbs, I decided to test the carbs off of a friend's NSR using my old jets. With his carbs, my bike ran PERFECTLY. Absolutely zero issues.
Clues 3-
So, knowing that it was an issue with my old carbs, I got a used set from Japan. Cleaned em up a bit, put my old jets in, and used my old float bowls because the ones from Japan got damaged during shipping. Fires up first kick from cold but, still the exact same problems and symptoms as above.
I feel pretty confident that the motor is starving for fuel, but I can't wrap my head around where. I'm thinking it's drawing a bunch of gas while climbing the power band and not refilling the bowls fast enough. Open to any other ideas too.
TIA!
ps - to make it all the more interesting, I've also just rebuilt the top and bottom end of the motor. However, I believe I can rule this out as a cause since the bike was running perfectly with my friend's carbs in place (clues2) and it had the same symptoms before the motor work.
