Is it just me or do I hear a knock?
prelude2.2
Mon Feb 19, 2018 1:37 pm » Post: #1 » Download Post
So I went out to start my NSR after the winter and it sounded like there was a knock coming from it. Maybe its just me. Let me know what you think, I hope you can hear everything okay in the video.
https://vimeo.com/256411426
knock.
Mon Feb 19, 2018 9:36 pm » Post: #2 » Download Post
Definitely something rattling there, almost sounds like a small end rattling, but before you start getting too worried check things like your clutch, ie, has the centre nut come loose ?, could be a miriad of things, strange if it was ok when you last put her away. Oddly enough, last year, i had a rattle develop on my RS250 at a track day, convinced it was the clutch come loose, i couldn't find anything wrong till i got home and found an engine mount had come loose and the nut was just rattling away like the clappers. Just go round it and make sure nothing has come loose before you go digging too deep, hope it's not too serious. Cheers Les.
prelude2.2
Mon Feb 19, 2018 10:00 pm » Post: #3 » Download Post
thanks Les. I will definitely have a look over the weekend
prelude2.2
Tue Feb 20, 2018 8:08 pm » Post: #4 » Download Post
Anyone else hear much or suggest what i should look at when i have time to look at it the weekend?
bushman
Wed Feb 21, 2018 4:43 pm » Post: #5 » Download Post
As Les says, check around for something loose first. You did however have that 2T oil pump seal issue, and may have had starvation, Did you use the bike much after you fixed that?
prelude2.2
Wed Feb 21, 2018 5:25 pm » Post: #6 » Download Post
No bearly used it at all. I just took off the clutch cover and all the bolts are good and tight. I Checked all the mounts and brackets and they arr good. When i pull in the clutch it doesnt change. However when i rev it, it does get louder with the revs. Im starting to think its in the engine. It certainly sounds that way too.
prelude2.2
Wed Feb 21, 2018 5:45 pm » Post: #7 » Download Post
had a hour or two so i went out and checked it. checked everywhere and took the plastics off before i started it so i could source the noise. Its definitely coming from the engine. sounds like the big end but its hard to tell. i literally feel like crying.
Oh Dear
Wed Feb 21, 2018 9:04 pm » Post: #8 » Download Post
Hi there
I am not convinced its big ends, It doesn't sound like 2000 rpm knock to me, It sounds more like transmission, first thing I would check is flywheel bolt then check the clutch hub nut holding clutch basket to main shaft there is a spring washer and a tab nut to dent in maybe its come undone
I spoke with Arron tonight and he said he will reimburse you and collect it if you want to sell it,
Good luck,
jonmac
prelude2.2
Fri Feb 23, 2018 11:55 am » Post: #9 » Download Post
Just had a few hours with it. Im fairly happy it isnt the big or small end. I will check what you mentioned. Thanks again for all your help Johnny
