I've jacked up the rear with the hrc plates, stiffened the front & the bike feels good.
I knew the chain would rub the front rubber/ swingarm and it did.
I only did 2 sessions as it was flogging out fairly quick.
I was going to make up some linkage plates a little less aggressive and probably drop the front a bit.
Massive problem is I can't hold as much corner speed and the belly pan scrapes!!
Any ideas on raising the r2j with out fouling the front of the swingarm. I want to get it up 35 to 40mm in the rear from stock.
I've had a look at putting a mc21 swingarm on but someone will probably have a cry because it's not period 6 (before 1990) for historic racing in Australia.
Any ideas?
thanks legends
Chris _________________ NSR250R MC18 R2J
Australian Historic Racing 🤘🏻
At the moment I've got emulators in the front as ive got no comp or reb
I've made some more linkage plates raising it about 20mm, standard shocks got no comp or rebound either.
I have got a F3 600 shock on the way so that should give me some comp & rebound
good advice tho mate, cheers
