R6K stuck in gear
Manny514
R6K stuck in gear
Sat Jun 01, 2019 2:37 pm » Post: #1 » Download Post
Hi
Just had the engine apart all seemed ok started up fine, clutch in select 1st, a quick squirt up the road going up the gear box no issue. The problem arose when I went to change down, I couldn’t!
With the engine switched off I could change back down to 2nd, but couldn’t get neutral or first.
Any suggestions as to where I start my investigations?
Sun Jun 02, 2019 6:38 pm » Post: #2 » Download Post
The gear selector pawl pulls the selector drum in either direction. The pawl spring sits either side of a post. It's worth checking it's not jumped over the post
