mc 16 to mc28 kits barrels, piston and rings compatibility
panchonsr
Thu Apr 02, 2015 3:12 am » Post: #1 » Download Post
hello friends...do you know if the complete head kits (barrel, piston,rings and head cam) It is compatible with all models engines nsr (mc16 to mc28)???..... Very Happy Very Happy Very Happy
Thu Apr 02, 2015 10:55 am » Post: #2 » Download Post
Everything is interchangeable, to a point. To keep it simple*, keep heads, barrels, and pistons together.
For example:
  • 1987 MC16 head/barrel/piston combination fits all years**
  • 1988 MC18R head/barrel/piston combination fits all years
    1988 MC18SP head/barrel/piston combination fits all years
  • 1989 MC18R head/barrel/piston combination fits all years
    1989 MC18SP head/barrel/piston combination fits all years
  • 90~93 MC21R/SE/SP head/barrel/piston combination fits all years
    90~93 MC21SE/SP head/barrel/piston combination fits all years
  • 94~97 MC21R head/barrel/piston combination fits all years
    94~97 MC21SE/SP head/barrel/piston combination fits all years
DO NOT mix the R/SE/SP heads/barrels/pistons.
*This is a basic compatibility, to keep things simple.
**MC16 parts will lower the performance of all other models, due to substantially smaller exhaust ports, and lower compression. The top coolant hose orientation on the MC16 is also slightly different to all other models. Conversely, fitting MC18/MC21/MC28 parts to an MC16 will increase its performance, but do not expect 60hp without plenty of additional work.
panchonsr
Thu Apr 02, 2015 11:02 pm » Post: #3 » Download Post
ok andy...thanks a lot men!!... Wink Wink in this moments my bike have a one kit of mc18 and the other mc21....that is dangerous??......yesterday i saw cylinder head for mi other new kit mc21 barrels but seller ask me how which i preffer....H or L cylinder heads....what differences betwen??...
Fri Apr 03, 2015 4:56 pm » Post: #4 » Download Post
Please search for KV3L and/or KV3H.
Username
Tue Oct 15, 2019 4:36 pm » Post: #5 » Download Post
Andy wrote:DO NOT mix the R/SE/SP heads/barrels/pistons.
Hi Andy...I thought I read somewhere HRC fitted or recommended K3VH 'SE/SP' heads to 'R' cylinders though?
Mon Nov 04, 2019 8:10 pm » Post: #6 » Download Post
You might be thinking of this:
It's definitely NOT recommended to mix the heads and barrels though. The NSR is extremely sensitive to increases in compression, and it's very easy to induce detonation with even minor increases. Hence why a 0.6mm HRC base gasket is recommended when fitting the top head to the lower barrel on the MC21/MC28.
