MC28 Forks - two things - Identify and Peace Talks
Max
Tue May 26, 2020 5:46 pm » Post: #1 » Download Post
Hi
It seems from an earlier round of discussion that I have MC28 forks fitted to my MC21.
1.
Can anyone tell me the easy way of identifying R, SE & SP forks?
My forks have a preload adjuster and a little brass damping adjuster (rebound?) in the centre of the preload adjuster. I can't see any further adjustment..I want to know for sure so that I can rebuild them with the correct oil level etc...are they SE?
2.
The little brass damping adjuster in one of the forks has been wound down tight into the preload adjuster, it has been tightened so much it has a mullered screw slot and to top it all off it is probably corroded into place. So far I have stripped it all out, tried heat and WD40...oh and I swore at it a LOT this afternoon, but it is staying put!..any tips for removing the awkward blighter!!
prelude2.2
Tue May 26, 2020 5:58 pm » Post: #2 » Download Post
they sound like SE forks. do you have a picture?
Max
Tue May 26, 2020 6:10 pm » Post: #3 » Download Post
Oh yeah, I forgot about that...they are in a gazillion bits at the moment but here is a before
prelude2.2
Tue May 26, 2020 6:32 pm » Post: #4 » Download Post
They look like SE, Hopefully someone can confirm. They definetely are not SP forks
Max
Tue May 26, 2020 6:43 pm » Post: #5 » Download Post
prelude2.2 wrote:They look like SE, Hopefully someone can confirm. They definetely are not SP forks
Cheers Prelude, I suspect you are right with the SE
prelude2.2
Tue May 26, 2020 9:40 pm » Post: #6 » Download Post
Im selling a very good set of SE MC28 forks. Less than 7000km done on them from new. I am selling them at a discount for people on the forum, PM if you are interested.
Wed May 27, 2020 1:44 am » Post: #7 » Download Post
"R" Preload only (no little brass rebound screw)
"SE" Preload & rebound (little brass screw)
"SP" Preload & rebound (anodised blue rebound adjusters)
Max
Wed May 27, 2020 6:43 am » Post: #8 » Download Post
Andy wrote:"R" Preload only (no little brass rebound screw)
Can I check with you Andy (just before I order one up), the component we are talking about is 51454-KV3-781.
Actually I found out all about this component in another thread, apparently the blighter I am looking for does not come available as a separate component, it is attached to the damper road assy...
Anyone know if a CBR400 or anything else fits the bill? Image enc.
