Mc18 cylinder
kangranwang
Mc18 cylinder
Sat Jan 09, 2021 8:23 pm » Post: #1 » Download Post
Recently i found that one of the cylinders died. There is very little smoke coming out from one of the exhausts, and that exhaust is cold. Anyone knows where I can get a new cylinder?
Tue Jan 12, 2021 8:34 pm » Post: #2 » Download Post
Have you looked into getting your existing cylinder replated? That would be the first thing to try. New old stock cylinders are fairly rare and expensive
kangranwang
Thu Jan 14, 2021 3:47 am » Post: #3 » Download Post
RobH wrote:Have you looked into getting your existing cylinder replated? That would be the first thing to try. New old stock cylinders are fairly rare and expensive
I haven't heard about cylinder replating. But I just did a quick research online and it seems like it requires professional work. I'm not sure if I can do this myself. I asked my mechanic and he said he hadn't done this before.
Thu Jan 14, 2021 11:26 am » Post: #4 » Download Post
Cylinder plating needs to be done by a specialist company, here in the UK you could count on one hand companies capable of doing this. It involves cleaning the old cylinder and re nikasil the surface. Are you sure this is the problem, when you say the cylinder has died, do you mean it's not firing, ie spark, have you looked at all the obvious, ie plug, coil, etc. If you google Nikasil cylinder replating, you should be able to find a company that does it. Normally, if your cylinder needs replating you will need a new piston as well, so the replating company will need the new piston as well. One of the big problems of owning such a machine like this, is, nowadays modern mechanics have no experience of these engines, and some probably wouldn't have ever heard of Nikasil. Try to find a two stroke tuning specialist, or talk to Rising Sun Cycles, these should point you in the right direction. Good luck.
Thu Jan 14, 2021 4:15 pm » Post: #5 » Download Post
https://www.uschrome.com/nicom-nikasil-cylinder-coating-and-repair
Thu Jan 14, 2021 5:13 pm » Post: #6 » Download Post
If that don't sort him out Andy, nothing will, I have my doubts that this is the problem though.
Thu Jan 14, 2021 9:07 pm » Post: #7 » Download Post
Possibly, Les, but when faced with little to no information.... Confused
