Carburetor & TPS Coupling
BARIE
Tue Aug 03, 2021 4:14 am » Post: #1 » Download Post
Hello everyone
I have NSR 250 R2J.
1. Do anyone have drawing for little coupling which connect between carburetor and TPS (Throttle position sensor)?
2. According manual book for basic setting carburetor, please help me which one carburetor no 1, and which one number 2?
Is up cylinder (left side) are number one, and down cylinder (right side) are number 2?
thanks for your help
Wed Aug 04, 2021 4:56 pm » Post: #2 » Download Post
Hi Barie
I'm a newbie here so not at all knowledgeable so sadly can't help as mine is in pieces do you have any pictures and I can look at what I've got
As for which cylinder in classed as #1 and which one is #2 I'll have to pass on that as well
I'm sure Andy or Rob will be able to answer the question real easy
Wed Aug 04, 2021 10:40 pm » Post: #3 » Download Post
The upright [vertical] cylinder is #1.
BARIE
Fri Aug 06, 2021 6:34 am » Post: #4 » Download Post
Dear, Andy
Thanks for the information
Now already clear cylinder & carb no 1 and 2.
For coupling TPS do you have drawing?
the white plastic
Sun Aug 08, 2021 1:54 am » Post: #5 » Download Post
I don't, I'm afraid. I have 3 sets of carbs here, and all are HRC F-III, that don't have a T.P.S., so I can't take a set apart to measure.
If I can get my hand on a set of standard carbs, I'll happily do a drawing for you though. In the mean time, I might know someone who can help. I'll drop him a line.
BARIE
Mon Aug 09, 2021 1:20 am » Post: #6 » Download Post
Dear, Andy
Thanks
BARIE
Mon Aug 09, 2021 2:44 am » Post: #7 » Download Post
Dear, Wayne
Just look your posting, herewith picture from your post, this white little thing
Thanks
Tue Aug 10, 2021 10:07 am » Post: #8 » Download Post
Is this the part?
how to take screenshots
BARIE
Wed Aug 11, 2021 1:32 am » Post: #9 » Download Post
Dear, Robh
Yes correct
is this exactly 90 degree between front and back?
Wed Aug 11, 2021 7:41 am » Post: #10 » Download Post
Yes. I can take a better picture and get dimensions if it helps?
I couldn't see a part number on my parts guide
BARIE
Tue Aug 17, 2021 3:40 am » Post: #11 » Download Post
Dear, Robh
Sorry just make sure, so the angle between left and right connection are 90 degree (carb side and TPS side)
OK Thanks for the information.
For the size no problem I can calculate by myself in my carb & TPS.
thanks
Tue Aug 17, 2021 4:31 am » Post: #12 » Download Post
Yes, 90 degrees
