Mc18 not revving out?
Liffy163
Sat Aug 28, 2021 2:09 pm » Post: #1 » Download Post
First of all hello was on here years ago as liffy16 but I could not retrieve my account as my email had changed.
Anyway rebuilt my mc18 this winter had crank rebuilt by Steve at Gt, top end was ok just new rings.when first rebuilt after running in bike was flying and would rev clean up to redline.
Now though it won't rev past 10k checked float heights and there at 13mm even removed pump as I think keep valve is leaking,so now on premix at 30=1 anything else I can try regards colin
Liffy163
Wed Sep 01, 2021 9:51 am » Post: #2 » Download Post
Ok update went to bike meet last night after about a 20 mile run bike started running better, pulling like it used to ,could it be some sort of electrical gremlins?
Wed Sep 01, 2021 2:40 pm » Post: #3 » Download Post
Could be old fuel or low battery charge. It's unlikely to be connections unless you have disturbed them.
Liffy163
Wed Sep 01, 2021 7:30 pm » Post: #4 » Download Post
Thanks for the reply does the battery need full charge to operate power valve?don't think it's fuel done a few tanks of fresh v power recently
Thu Sep 02, 2021 9:27 am » Post: #5 » Download Post
If you use the search with power valve battery, you will get several topics similar to your question
Also, the power valve switches to a config setting at 2000 rpm, so you can check it is set correctly. It's worth reading through the tuning section for power valve setup https://nsr-world.com/tuning/250-tuning/engine/
tleighbell
MC18 not revving out
Thu Sep 09, 2021 8:44 pm » Post: #6 » Download Post
HI Rob H or Andy. Went to the link about tuning/powervalve and the last section re: power valve mentions a diagram but i did not see the diagram. Can someone provide a link? thanks.
Re: MC18 not revving out
Fri Sep 10, 2021 12:19 pm » Post: #7 » Download Post
tleighbell wrote:HI Rob H or Andy. Went to the link about tuning/powervalve and the last section re: power valve mentions a diagram but i did not see the diagram. Can someone provide a link? thanks.
Should see this:
tleighbell
Fri Sep 10, 2021 1:47 pm » Post: #8 » Download Post
Thanks Andy
Liffy163
Sat Sep 11, 2021 6:23 pm » Post: #9 » Download Post
Update on nsr checked battery and as it's not very old it was good and stator is charging ,so tweeted float heights about 0.5 mm and it's going like a nsr should again,thought clutch had started slipping at about 9 k but no this is how it should go like😁👍chuffed or what
Sat Sep 11, 2021 7:52 pm » Post: #10 » Download Post
Great news, and thank you for posting your fix.
Liffy163
Sun Sep 12, 2021 10:44 am » Post: #11 » Download Post
Andy wrote:Great news, and thank you for posting your fix.
No problem Andy, I knew this bikes were sensitive to float heights but that's something else, hardly moved them,just in the tolerance 13.5mm from 13mm
tleighbell
MC18 won't rev out
Wed Sep 15, 2021 4:35 pm » Post: #12 » Download Post
Maybe you just blew the dead spiders out of the carbs.
