MC18 water outlet
kangranwang
MC18 water outlet
Fri Apr 29, 2022 4:10 am » Post: #1 » Download Post
I just found my MC18 water outlet broke. It has a big hole in it. I’m not sure if it’s called water outlet but it connects the water pump with the 2 cylinder heads. I attached a picture in this post. Now my technician just put some cohesive on it so it might be fine but i don’t feel safe at all.
Anyone knows where to get one now? Thank you!
Fri Apr 29, 2022 2:01 pm » Post: #2 » Download Post
The part 19410-KV3-000 is NLA
There's a used one on eBay https://www.ebay.co.uk/itm/313972555797?hash=item491a390015:g:MfgAAOSwrUxiZybb
kangranwang
Sat Apr 30, 2022 12:29 am » Post: #3 » Download Post
RobH wrote:The part 19410-KV3-000 is NLA
Thank you RobH! Just ordered! Thankfully I can still find one.
Interestingly the seller doesn't ship to the US so I had it shipped to Canada.
Sat Apr 30, 2022 10:19 pm » Post: #4 » Download Post
Just a side note: I'd strongly recommend against using the bike with that "repair".
kangranwang
Sun May 01, 2022 12:52 am » Post: #5 » Download Post
Andy wrote:Just a side note: I'd strongly recommend against using the bike with that "repair".
Hi Andy,
What repair? Are you talking about the item that RobH posted?
Sun May 01, 2022 8:07 pm » Post: #6 » Download Post
No, I mean with your current repaired part. I wouldn't trust any kind of "epoxied" repair on the cooling system. I've seen leaks destroy a motor faster than you can grab the clutch.
kangranwang
Mon May 02, 2022 4:32 pm » Post: #7 » Download Post
Andy wrote:No, I mean with your current repaired part. I wouldn't trust any kind of "epoxied" repair on the cooling system. I've seen leaks destroy a motor faster than you can grab the clutch.
I see. But my water outlet has a big leak and if I don't replace it then the bike cannot work. Do I have any other way around? I've also ordered a fan with a switch I wish that would help.
Tue May 03, 2022 9:39 am » Post: #8 » Download Post
I think what Andy is trying to tell you, is, DONT use the bike with the repair that your technician has done. Just to be on the safe side.
Tue May 03, 2022 4:22 pm » Post: #9 » Download Post
I'd honestly just wait for the new (used) part to arrive. Epoxy is notorious for failing in cooling system repairs. The hot coolant seeps between the base material and the epoxy and the pressure blows it out. You may be lucky, but it you're not, at best you'll likely seize a piston, but worse case scenario is a totalled motor and you laying in a ditch at the side of the road.
I speak from experience.
kangranwang
Mon May 09, 2022 3:49 pm » Post: #10 » Download Post
Thanks Andy! The part would come in a month because it's from the UK and I live in North America, but I guess I would wait then:)
Wed May 11, 2022 1:41 am » Post: #11 » Download Post
I don't understand why it would take more than a few days. I sent a brake line kit to Florida recently and it took 4 days to arrive.
kangranwang
Thu Jun 02, 2022 6:02 am » Post: #12 » Download Post
Andy wrote:I don't understand why it would take more than a few days. I sent a brake line kit to Florida recently and it took 4 days to arrive.
Update: finally received the water outlet from the UK. Now everything works. I noticed more smoke coming out from the pipes. I guess some part of the bike was leaking and we just fixed it.
It takes long because the part comes from the UK so shipping took almost a month.
Thu Jun 02, 2022 10:30 pm » Post: #13 » Download Post
Glad it's all fixed. Still can't understand why shipping took so long though.
