Hi guys I have swapped the pipes on my r2j to the later rk5 and made some brackets as the rear subframes are obviously different. Do you guys recommend that I reject the carbs to suit or is the difference negligible. Jim
Welcome to NSR World. Jetting is not discussed in this section. I believe it is discussed in the members section. As with any modification(s), no matter how small, you should check and re check your jetting.
As Sami says, we don't allow jetting discussion in the public area, for silly historical reasons. Further qualifying Sami's post, it is indeed absolutely recommended that the jetting is carefully checked whenever any modification is made. There's generally quite a large [rich] margin built into the stock jetting to cover a wide range of atmospheric and topological conditions, but I wouldn't rely on those stock settings to be suitable to also cover mechanical changes.
