Does anyone have a trick for accessing the float bowl drain screws other than removing the carbs? On my bike there is a bump on the crankcase that blocks access to the screw on the right hand/front cylinder carb. And the frame etc. etc. blocks access to the drain screw on the left carb.
Thanks to all who respond
