Really Dumb Question
tleighbell
Fri Oct 27, 2023 9:15 pm » Post: #1 » Download Post
Does anyone have a trick for accessing the float bowl drain screws other than removing the carbs? On my bike there is a bump on the crankcase that blocks access to the screw on the right hand/front cylinder carb. And the frame etc. etc. blocks access to the drain screw on the left carb.
Thanks to all who respond
ericandchi
Carb drains
Sat Oct 28, 2023 11:43 am » Post: #2 » Download Post
I've yet to find an easy way. I did consider putting small valves at the end of the hoses then leaving screws open so they would be easy to drain, but then i decided that might not be very safe. So, I take the carbs off. It's a bit easier because I don't have the air box anymore, but I think we all feel your pain.
Sat Oct 28, 2023 7:02 pm » Post: #3 » Download Post
What model? I don't have any problems with my MC21, but like Eric, no airbox. (Just pod filters.) Just need a long thin driver.
Something like this...
https://kaisertech.co.uk/1-0x5-5mm-200mm-slotted
tleighbell
Sat Nov 04, 2023 9:37 pm » Post: #4 » Download Post
Thanks Eric & Andy. MC18 frame, MC28 engine but carbs are for MC18. I'll look for a screw driver like that, hopefully with a bit of flex in the shaft.
