Do you mean it won't bite - engage - or it won't release - disengage? _________________ MC21SP Plaything
Is it hard to get in gear too? _________________ MC21SP Plaything
hmmm.....it slots into first quite nicely i think...i have taken it for a ride and it does seem a bit harder to shift than my other bike.
the clutch cable has a few fibres worn/broken near the bars...could that area be stretching when pull the lever? so its not fully engaging the clutch? _________________ Philip Ahn
MC21 NSR250R
Yes you muppet! Change it now - it'll be dragging inside the liner and making clutch operation much worse. _________________ MC21SP Plaything
Does it drag when it's running and in gear ? does the bike want to go foward in other words ?
When it's not running it will feel that way, just went thru the same thing. Bought all new parts, took everything apart and couldn't find anything wrong. Put it back together and it worked fine. If it has been sitting a long time a little rust on the steels can make it act-up. Hey if you need new parts for a wet clutch MC21 I got them. _________________
