if it helps, my bike did a round trip of 200miles and i used 1ltr of oil, she was toped up before ride and then during and at the end, total 1ltr, dont forget the tanks bigger than it looks, when i bought mine i though id run dry but found that the little tank at the side is the tip of the iceburg so to speak...there is a bigger tank under the tank that the little one feeds.
How is your gear oil ? The seal in the injection pump can fall-out and fill you gearbox. You might not be burning as much as you think ! _________________
a tip i learned from our Andy about this is always top your oil back up to the top after a ride, that way you will know if the seal has gone when you come back to the bike the next time. _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
When you say topping up do you mean you're putting in like 500ml? Or is it taking loads more? Check the adjustment of your oil pump as well. Could be that its pumping way too much http://tech.nsr-world.com/nsr/nsr-all/oil-pump/
bryan_au wrote:When you say topping up do you mean you're putting in like 500ml
i mean fill the resevoir after every ride, sorry i have no idea relly how much oil i use, i recon its about 1/4 of the visible resevoir to 100 miles.....ish _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
