I'm thinking of changing my gearbox oil for the first time. Any suggestions? I live in the USA and Rockoil is not available. What kind of oil should I use? Is it 10w30?
Rockoil can be got in the states, Go to NSR-worlds home page and click on the Rockoil link. At the bottom there are some contact details. Both myself and Andy use Rockoil GRO, good stuff. _________________ If I have to take the carbs off once more...
I'm in the US and I use Spectro 80W Gear oil (not Hypoid Gear oil) for my SE and Spectro Clutch Saver for my R. They are both equivalent to 10-30 and any motorcycle shop that services dirt bikes should have it. _________________
S15DET wrote:My dipstick is broken off at the cap. Can someone tell me how high the oil should be, so I can use a finger or something to set it?
It is not broken , but looks that way.
It is not a dipstick, only a filler cap!
Please don't set a level with your finger.
You just have to put the correct amount of oil in the gearbox.
its on the side of the engine, clutch side at the bottom below the clutch, big ugly bolt, as i say is on the side dont look underneith like a 4 stroke. rember 700 ml, cheers
