one of my fork seals started leaking..so i wanna replace it.
the fork had some rusting on it which i have got most of off..but there are still specs of black dots that are protruding(pitting?). i think they were the cause of the fork seal to bust.
any ways to get it off....i dont really have money to get them re-chromed etc..
The other option is to buy some aftermarket stanchions, which are usually a cheaper option than going the re-chroming route. _________________ NSR300R - Why did i ever have a 250...
The shiney bit at the top. Properly called a 'fescalized' rod.
Your forks have a fork tube and a fork slider (the top bit and the bottom bit on conventional forks), but go by various other names just to confuse you! _________________ MC21SP Plaything
hmm...
i heard that you can actually rub the "dots" back and then fill the little holes with ladies manicure believe it or not!
"looks like sh*t, but its a quick and cheap fix" (quote the guy)
not sure if it works tho...
im not sure what he told me to rub it back with tho. _________________ Philip Ahn
MC21 NSR250R
You will only be buying time I'm afraid, and will need a re-chrome sooner or later as the seals will only cope with a certain amount of damage.
My FJ ones are bad, and I've got them through the summer, but I think it's rechrome time now... _________________ MC21SP Plaything
I use a needle file, and a lot of care... _________________ MC21SP Plaything
I know they aren't the cheapest, but they are genuine Honda parts, and you do get an oil seal and a dust seal in each kit. (1 kit required for each fork leg.)
Frankly, I can't understand how some companies can be selling original Honda parts at the prices they are quoting! Even with full UK Honda Dealer discount (which obviously I DON'T get!), I couldn't sell the seals much cheaper!
Go on, live dangerously and support the Site a little! _________________ Andy.
