Thats my understanding too, So 15ltrs fuel 500ml oil, 30ltrs fuel 1 liter oil!!!! but wait for a confermation..... im only going on what ive seen others do at tracks!
you might want to get yourself a ratio rite. it will make the premixing simple. you can get them at your local bike shop. and yes the 30:1 means 30 parts fuel to 1 part oil. hope that helps. _________________ To much HP is barely adequate!
I found it easier mixing 4 1/2 litres at a time, pouring in 150cc of oil (4500cc / 30:1 = 150cc)
As most mixing jugs are either 5 or 6 litres it made it easy.
Try and buy yourself a measuring tube/cup with small increments for the oil as the marking on most jugs are not accurate enough.
Don't forget to invest in a "weather station" as well for the jetting.
By the way Andy has given you your own board for the RS discussions etc.
http://www.nsr250.net/forums/index.php
You better start using it before he starts SHOUTING at you
I don't think keeping leftovers for a few months will hurt, just remember to shake the fuel before using it to re-mix it. Some of the oils will seperate from the fuel after time. Hope that helps. _________________ To much HP is barely adequate!
Maybe I could've worded it a little better, but every Forum area has to start somewhere. It may "look" lost and forgotten now, but if you use it then it will become busier.
You'll see, this topic won't run here much longer! _________________ Andy.
