G'Day all,
             Finally found the problem, a totally blocked no.2 slow jet. The bike runs well now and is slightly rich (#42 slows, mains not readable) on a stock engine. Compression was 80psi front 85 rear, is this OK? I am considering changing to Unifilter oiled foam pods, are these OK and will my jetting need to be changed over the  stock box and filter? lastly the wiring connecting to the Rc valve is unplugged due to u/s servo motor, will running the bike like this cause damage to the PGM unit.
Thanks for your time.
