as the title sugests i've obtained an sp motor is it a straight swap putting it into an r?? _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
As far as I know, yes. Only the clutch and barrels and heads and cool factor are different, not the mounting points. _________________ MC21SP Plaything
whats different with the barrels & heads, am i getting more donkeys _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
Some are longer and some are higher compression - can't remember which way round it is. _________________ MC21SP Plaything
You can swap them around, as all heads bolt to all barrels and all barrels bolt to all cases, but beware of fitting SP heads on R barrels as it will up the compression and cause problems unless you tune the motor to suit. _________________ MC21SP Plaything
All heads & barrels are interchangeable for any particular model, but make sure you don't mix heads and barrels of different types, ie. "R" head on an "SE/SP" barrel.
Heads and barrels are identified by "H" or "L" castings in them. Use either a KV3L head with a KV3L barrel, or a KV3H head with a KV3H barrel, and you won't go wrong.
You'll have all the bits soon... a little detective work and you'll know what's what. It's not rocket science!! _________________ Andy.
Ah! I only asked becasue i have the se (well now an R with se suspension) up for sale and if she dosent sell i might strip her down and sell all the bits but keep some spares for me.....always good to have spare barrels or i could fix the last few bits and have 2 21's
Believe me man, its quite quick enough the way it sits! A cheap engine for you regardless of the type! _________________ NSR250R MC21 (NEARLY SOLD!!)
VFR400R NC30 (SOLD)
Santa, please bring me a NSR500 and a SP-2 next year. Pleeeeease....
nsrbelfast wrote:Believe me man, its quite quick enough the way it sits! A cheap engine for you regardless of the type!
lol, you're probably right mate, its just that i've got the tinkering bug now _________________ If you dont like the way that i ride.....Stop trying to keep up!!!!!
Did you get my text message mate? _________________ NSR250R MC21 (NEARLY SOLD!!)
VFR400R NC30 (SOLD)
