What do you guys use to seal the crank case up after replacing the crank. Is it some kind of gasket maker that Honda sells, like Yamabond? _________________
Awww man! I'm sorry dude! Wanna go to streets next month? when is your bike going to be ready?
Its was so much fecking fun! I finally got to feel what the NSR was meant for. It makes not want to ride on the street anymore. _________________ MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
STEVE,
I used Permatex MotoSeal 1 Ultimate Gasket Maker Gray item #29132. Believe it or not, this is what the Honda dealer in Japan gave me to use for sealing the cases.
PM me your home email address and I will send you a few really good pics that I obtained from JHA that explain how to properly port and epoxy your NSR cases. _________________ Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
Permatex MotoSeal 1 Ultimate Gasket Maker works well, but it's a bugger to use. Pretty much the same as Threebond 1104.
Threebond 1211 is what I use and it's good, but it takes a little time to cure. Another very good one is Threebond 1207B, but costs a small fortune. HRC use this.
Alternatively you could use raspberry jam. Doesn't work at all, but you get to lick it all off the motor as it squidges out.
