Interesting, if you're running the right version of Java the screen should be divided into 4, the index list (top left) the microfiche (top right), a blank square (bottom left) and the part numbers (bottom right), like this;
_________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Ye, because I like to listen to Andy complain... I designed the layout to require a pretty damn big monitor (or a high resolution). If you got a small resolution then the bottom frames may not show up as the top frames will most likely take up the entire screen.
Sorry... it was the best way I could do it and make it look kind of okay. _________________ Charles Gallant
That'll teach you to run 640*480 or whatever silly res you're running, play the game peeps, at least 1024*768 surely??? _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
