online parts maunal
sparky
online parts maunal
Mon May 08, 2006 5:56 am » Post: #1 » Download Post
I was looking through the online parts manual, but could not find any part numbers. are they not available or am I not looking hard enough?
Mon May 08, 2006 11:00 am » Post: #2 » Download Post
Interesting, if you're running the right version of Java the screen should be divided into 4, the index list (top left) the microfiche (top right), a blank square (bottom left) and the part numbers (bottom right), like this;
sparky
Mon May 08, 2006 11:36 am » Post: #3 » Download Post
I don't get the bottom part at home.
but I checked at work and it looks like your screen shot.
Thanks Embarassed
cgallant
2001 Honda RS250
Mon May 08, 2006 11:01 pm » Post: #4 » Download Post
Ye, because I like to listen to Andy complain... I designed the layout to require a pretty damn big monitor (or a high resolution). If you got a small resolution then the bottom frames may not show up as the top frames will most likely take up the entire screen.
Sorry... it was the best way I could do it and make it look kind of okay.
Charles Gallant
Mon May 08, 2006 11:17 pm » Post: #5 » Download Post
That'll teach you to run 640*480 or whatever silly res you're running, play the game peeps, at least 1024*768 surely???
