I can divulge the oil information later, after consulting the NSR Bible! The strip-down is pretty straight-forward, and I'll let you know the part numbers later too; once I get home.
I think stock oil is 410cc per leg, I went for 420cc cos im too tall and too fat for the average NSR fork. I also used 10w oil. I cant remember the air gap now sorry. _________________ If I have to take the carbs off once more...
Any more info on how to do the fork seal replacement? I currently have the forks off the bike, I have undone the bolt at the bottom which I thought held the forks together, however they are still not coming apart so I cannot change the seals.
ANy help or instructions would be gratefully received!
First you have to remove the fork dust seal. Under that you will find a wire clip. Flick that out and then pull the leg out. It will be stiff as you are also pulling out the oil seal at the same time. You normaly have to yank them pretty hard. hope that helps _________________ If I have to take the carbs off once more...
The seal kit part number is 51490-MN8-503. You will need two kits (one for each leg of course). _________________ If I have to take the carbs off once more...
