MC28 upper work on MC21?
Jim
Thu Feb 19, 2004 6:54 pm » Post: #1 » Download Post
Does anyone know if the MC28 upper is a direct bolt on for the MC21, or is it the case that some modification is needed, e.g., change fairing stay too? Thanks for any information.
-Jim
-Jim
'93 MC21
cgallant
2001 Honda RS250
Thu Feb 19, 2004 7:10 pm » Post: #2 » Download Post
Jim,
I attached an MC28 upper onto my MC21 with no issues. Even matched up to the lowers just fine.
Thanks,
Charles Gallant
Guest
Thu Feb 19, 2004 7:29 pm » Post: #3 » Download Post
That's a pleasant surprise! Thanks Charles!
-Jim
Steve
Tue Feb 24, 2004 2:35 am » Post: #4 » Download Post
Hi, I am a newbie. I am also planning to put a stock MC28 upper on my 1992 MC21. Do I also need to buy a new MC28 headlight too or the MC21 headlight will fit? I have also seen people putting the mC28 tail on a MC21. I think Charles did that but I realized 28 and 21 have different mounting points. Does that mean that people just change the subframe too?
Thanks,
Steve
cgallant
2001 Honda RS250
Tue Feb 24, 2004 2:40 am » Post: #5 » Download Post
Steve,
The headlights are the same. However, the wind screens are not.
As for the tail section. You can keep the same subframe, just need to make a couple little brackets that go from the lower subframe to frame mounts that allow you to attache the body to the bracket.
I know TYGA sends these brackets with their body work (if you ask for it), or you can just cut your own out of aluminum.
Thanks,
Charles Gallant
Steve
Wed Feb 25, 2004 3:42 am » Post: #6 » Download Post
Thanks for the info, Charles.
Steve
