rev counter problems (any ideas)
nigel
Sat Jul 15, 2006 8:58 am » Post: #1 » Download Post
getting to final bits on my ypvs/rgv build
the problem i have is i am using a clock cluster from a single cylinder bike (nsr 125)
the ypvs only has one coil and sending one pulse to the rev counter so the rev counter is showing 4 thou when it should be 8 thou and 5 at 10 etc
is the any electronic converters that may cure this
Half the strokes, twice the fun
Sat Jul 15, 2006 9:50 am » Post: #2 » Download Post
Erm, if the clock is from a single cylinder bike, and the YPVS has a single coil, shouldn't it work properly?
Any reason you're not using the YPVS clock?
It might be possible to split the line in and use a coil (inductor / choke) to delay the signal down the second line so that it arrives after the first and appears as a second signal.
Does that make any sense? Confused
nigel
Sat Jul 15, 2006 10:11 am » Post: #3 » Download Post
not using the ypvs clocks as mine were damaged and the nsr ones have a nice white background and red numbers/needle and were free
not doing the work myself but will pass on the idea to the chap that is
Sat Jul 15, 2006 12:57 pm » Post: #4 » Download Post
The YPVS rev counter most likely has circuitry inside that converts the signal from one coil to double the reading.
How does the YPVS fire?
Sat Jul 15, 2006 4:29 pm » Post: #5 » Download Post
This company make customised dial faces www.redial-uk.co.uk Dont know how it would look though because I guess that you would only be using half the dial?
Chester362
Sat Jul 15, 2006 5:07 pm » Post: #6 » Download Post
Dave Ett wrote:Erm, if the clock is from a single cylinder bike, and the YPVS has a single coil, shouldn't it work properly?
Err, I think it`s because the ypvs uses the "spare spark" method of ignition.
The coil`s firing twice per revolution, only thing is, I`d have thought the rev counter would have read faster. Not slower.
