my mates not having them cases now so ill have em off you for a bit of a winter project to see if i can get 80+ bhp form a nsr motor i got 42 from a nsr125 motor so am going to see if a 250 motor is up to the job
The width of the slide will determine how wide you can go., but beware of the intermadiate power jet exit of you'll cut straight into the main chamber hole.
You can cut them quite high. Lift the slide right up until it stops and you'll see.
Keep the 'D' shape, and don't be afraid to get the epoxy out to fill all the holes. Andy will know what I mean quite soon.
I have arrived! Its hot just like it was the time before and the time before that... down to see you in a couple of days Matt. _________________ If I have to take the carbs off once more...
