Guys I think I have a crank seal problem. I already post this about a month ago that my bike sometimes idle at 1500 then sometime it goes up at 4 to 5 thousand RPM. But my question is how can I be sure that its a crank seal problem? Could it be blocked jets cause I dont have fuel filter and the last time I opened by carbs it full of dirt in the bottom. could a block jets cuase this? I want to be sure because oil seal are quite pricey plus the trouble of opening the crankcase. any suggestion? or how to be sure what the problem is?
If you suspect the carbs are dirty, then clean them. And fit a fuel filter - remember all that dirt is being sucked into the crankcase and into the bearings. Not good. _________________ MC21SP Plaything
leak test: you have to fabricate some plates that can close the intake holes, where the carbs are and a sparkplug insert that will allow you to send pressurized air into the cylinder and then close it off. Then you wait to see if the pressure disappears again, indicating leakage.
Before you do this or take the crankcases apart, you can run the engine and spray some dieselstart aroung the crank seals to see if the rpms change when you do it. This will of course not check the middle crankseal, but that one does go bad very often.
You can use it for checking air leaks in other places on the bike too.
Don't spray it all over the place though as its highly flammable.
