Crank Seal Problem?
czsphl
Crank Seal Problem?
Sun Oct 29, 2006 9:37 am » Post: #1 » Download Post
Guys I think I have a crank seal problem. I already post this about a month ago that my bike sometimes idle at 1500 then sometime it goes up at 4 to 5 thousand RPM. But my question is how can I be sure that its a crank seal problem? Could it be blocked jets cause I dont have fuel filter and the last time I opened by carbs it full of dirt in the bottom. could a block jets cuase this? I want to be sure because oil seal are quite pricey plus the trouble of opening the crankcase. any suggestion? or how to be sure what the problem is?
Thank to all..
Sun Oct 29, 2006 10:11 am » Post: #2 » Download Post
If you suspect the carbs are dirty, then clean them. And fit a fuel filter - remember all that dirt is being sucked into the crankcase and into the bearings. Not good.
czsphl
Sun Oct 29, 2006 10:36 am » Post: #3 » Download Post
Ill fit the filter right away, but could dirt cause the inconsistent idling?
czsphl
Mon Oct 30, 2006 12:10 am » Post: #4 » Download Post
any more opinion guys? please anyone? matt?
fenton
1990 Honda NSR250 MC21
Mon Oct 30, 2006 12:14 am » Post: #5 » Download Post
get your spanners out and start stripping it down its not hard to pull a nsr motor apart or put in back together !
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Oct 30, 2006 1:33 am » Post: #6 » Download Post
Start by pulling the carbs off and having a look inside. If they're dirty then that may be your problem.
Sounds like an air leak of sorts though.
Can you get the motor leakdown tested?
czsphl
Mon Oct 30, 2006 2:30 am » Post: #7 » Download Post
How will I do that leakdown test? i have no idea about that.
pbekkerh
Mon Oct 30, 2006 7:54 am » Post: #8 » Download Post
leak test: you have to fabricate some plates that can close the intake holes, where the carbs are and a sparkplug insert that will allow you to send pressurized air into the cylinder and then close it off. Then you wait to see if the pressure disappears again, indicating leakage.
Before you do this or take the crankcases apart, you can run the engine and spray some dieselstart aroung the crank seals to see if the rpms change when you do it. This will of course not check the middle crankseal, but that one does go bad very often.
You can use it for checking air leaks in other places on the bike too.
Don't spray it all over the place though as its highly flammable.
google is your friend Wink
http://vmaxoutlaw.com/tech/leakdown_tester.htm
http://www.google.dk/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-38,GGLG:en&q=leakdown+test
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
czsphl
Mon Oct 30, 2006 11:35 am » Post: #9 » Download Post
Thanks man
