2t leaking into the transmission oill
dsgfh
Sun Dec 10, 2006 12:07 pm » Post: #1 » Download Post
G'day,
just found the forum while trying to find an answer to a problem I've found. Since I haven't found the answer though, thought I'd best just ask Smile
Prepping my bike today getting ready to head to the track, I'm changing the transmission oil, but when I took the oil cap/dip stick out, oil overflowed out. Rather than looking like the Motul transoil I put in there though, it was tainted with my castrol tts 2t.
I've drained it & replaced it, but was hoping someone could tell me how it's getting in there in the first place. Am I due for a full rebuild? Or is it a little less serious? Any hints would be much appreciated.
Sun Dec 10, 2006 12:40 pm » Post: #2 » Download Post
Hello and welcome!
It's the 2t oil pump seal, an easy fix, post about it here.
dsgfh
Mon Dec 11, 2006 11:55 am » Post: #3 » Download Post
Thanks for the pointer. Pulled the oil pump out & just as promised there was the seal half way down the shaft. Now clearly that's fine when it's the open end of a condom, but in this case a little silicone gasket & I've tucked it back in place. Once the gasket's dry I understand I have to bleed the pump before I reassemble the lot?
The search feature & I aren't quite friends yet, so are there any tips for this? I saw mention of a bleed screw in the other post. Is this on the side of the pump that faces the centre of the bike. Is it simply a matter of opening the screw & rotating the shaft to pump some oil through?
