Limited rpm in 3rd gear onwards
Markus
Mon Mar 12, 2007 11:21 am » Post: #1 » Download Post
I had my MC21 sp at the track last weekend and something funny was happening. 1st and 2nd gear revved all the way to red line but every other gear struggled, nay refused to pass 9,000 rpm.
What could cause this? I was thinking it could be RC valves or spark plugs? But I’m just a weekend mechanic that tinkers on my own bikes. Any help would be greatly appreciated.
Thank you in advance,
Markus
Mon Mar 12, 2007 8:55 pm » Post: #2 » Download Post
Bad jetting is what springs to mind first. Have you carried out any mods to it?
Oh, and where in the world are you?
Markus
Mon Mar 12, 2007 9:41 pm » Post: #3 » Download Post
Dave Ett wrote:Bad jetting is what springs to mind first. Have you carried out any mods to it?
Thanks you Dave for your response,
ahhh I should have mentioned that the bike was capable of reaching just under 200kmph but this weekend did not pass 140!, if it was jetting, wouldn’t I also have problems with 1st and 2nd gear? Aftermarket bits air filter, expansion chambers and exhausts but nothing has been changed on the bike since the above speed was reached.
I am in Sydney Australia.
Thanks for your help in this matter.
Markus
2-Strokes Rule
Mon Mar 12, 2007 10:20 pm » Post: #4 » Download Post
well i personally dont have any experiance with nsrs but juding from those mods u mentioned ALL would require the jets the be matched to suit (ie re jet the carbs).
Any modification to the way the bike breathes and exhales would be serious in terms of new jetting.
So id sugggest giving jetting a try...
Mon Mar 12, 2007 10:32 pm » Post: #5 » Download Post
I would check the fuel tap for flow and fuel tap filter first.
After that strip and clean the carbs.
If the bike was running well with the current setting there is no reason why it shouldn't again.
Quite often a bike lacking fule will rev out in the first couple of gears only to give up once the fuel demand is greater.
Markus
Mon Mar 12, 2007 10:34 pm » Post: #6 » Download Post
2-Strokes Rule wrote:well i personally dont have any experiance with nsrs but juding from those mods u mentioned ALL would require the jets the be matched to suit (ie re jet the carbs).
Can the jetting change so much as to cause 60km difference with no changes to air input and exhaust? As I said earlier I have made NO changes to the bike since this restriction in revs started.
If it is jetting why would 1st and 2nd not be affected?
thanks,
Markus
Markus
Mon Mar 12, 2007 11:03 pm » Post: #7 » Download Post
StephenRC45 wrote:I would check the fuel tap for flow and fuel tap filter first.
very interesting, thank you for your advice. makes allot of sence as the carbs would have had time to fill up again before 1st and 2nd gear are used.
I will check all this and keep everyone updated.
Thanks guys,
Markus
SLF-951
Mon Mar 12, 2007 11:28 pm » Post: #8 » Download Post
Sounds right on if the bike is running fine other that at top revs and load....
I've seen once the fuel tank vent get cloged on a dirt bike cause the same type symptoms. Same lack of fuel at top end....
MC21
04 NSR50R
93 CBR F2
98 CBR F3 track bike
95 VFR750
89 FL400R Pilot
90 FZR 4/600
Tue Mar 13, 2007 9:54 pm » Post: #9 » Download Post
Another possibility is the spark system - it's ok in the first two gears where load isn't so great, but isn't strong enough under more demanding conditions.
Check the connectors are clean and tightly fitting.
NickoPen
Sun Mar 25, 2007 11:29 am » Post: #10 » Download Post
Did you disconnect the dash? On the CBR250RR and vfr400, if you don't have the dash plugged in it won't rev right out above 2nd (stops dead on 9000 RPM). check your connections there first.
