trackday tires
ruff rider
trackday tires
Sat Mar 31, 2007 8:32 am » Post: #1 » Download Post
just wanted to know what you guys are using. trackday tires, size, brand, and also what psi is a good starting point. thanks
i have 120/70/17 and 150/60/17, mc28, supercorsa, front is rs250 forks and marchisini front rim. thanks
Sat Mar 31, 2007 5:05 pm » Post: #2 » Download Post
I run super corsa's on most of my bikes, really like them.
If your running the 3.5" RS front wheel then I would go with the 120 your using now or the 115/120 if you want to run a slick.
The 150 will be perfect for the 4.5" rear wheel unless you have the RS 5.00 or 5.25 which should really run a 160.
Tyre pressure really depends on the day.
ruff rider
Sat Mar 31, 2007 7:39 pm » Post: #3 » Download Post
ok, i also heard that a 120/60/17 would be better then a 120/70/17 for the NSR with RS250 front end is this true? while rear remain stock nsr with a 150/60/17. power races come in this size. thanks.
Sat Mar 31, 2007 10:02 pm » Post: #4 » Download Post
Personaly I like a 120/60 over a 120/70 but then again I think that more down to what I'm used too.
Sat Mar 31, 2007 11:47 pm » Post: #5 » Download Post
Logic dictates a 120/60 over a 120/70 every time.
120/60 is much closer in profile to a 110/70 than a 120/70 will ever be, and we all know how well the stock sizes work.
rodney007
Sun Apr 01, 2007 10:28 pm » Post: #6 » Download Post
gpr70's front
gpra10's rear
ruthless and expensive tyres,
Hung
Mon Apr 02, 2007 10:00 am » Post: #7 » Download Post
I run GPR70 Front and Rear, very nice....but bit cost more.....
Bridgestone 090ss is also nice...
1996 HONDA RS250
1995 MC28 NSR250 SE red/white/green
1994 MC28 NSR250 sp W/ RS250 engine
rgvsean
Mon Apr 02, 2007 12:35 pm » Post: #8 » Download Post
Gpr70 are now discontinued. Only the a10 (alpha 10) available now unless you can find old stock. I am on 70's and looking forward to trying the 10's. The 70's are quite a heavy tyre by modern standards so the 10's address this + use more modern construction/materials.
http://www.rgv250.co.uk
http://www.thetuningworks.com
wb
Tue Apr 03, 2007 8:05 pm » Post: #9 » Download Post
Had a good look at some of the new Alpha 10s today. They certainly look and feel the part. Always preferred Bridgstone BT090s over the Dunlops, but I think I'll give them a go this summer.
Wb
ruff rider
Wed Apr 04, 2007 5:32 am » Post: #10 » Download Post
are the a10s avalible in the US? i have not seen anyone sell/ride these types of tires? thanks
wapdad
Tyre pressures
Thu May 03, 2007 12:18 pm » Post: #11 » Download Post
I ran 28 psi front 30 rear on an MC21 with std wheels. Most would run 30/32 to start
You will need to drop them a lot from the standard road pressures to get the tyres to work.
GPR's were great and seemed to last quite well.
- 10 year old Japanese Bridgestones were 'interesting' at a cold wet Oulton Park. I got down to 25/27 which was better if a tad squirrely, but still not getting hot enough. (I weighed only 8 and a half stone at the time - better now).
Mike
jkolewski
Thu May 03, 2007 8:23 pm » Post: #12 » Download Post
I'm runing Michelin power race 120/60 160/60 on the NSR can't quite scrub them to the edges. I think because of the standard size rims.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
