Stock Airbox
china
Stock Airbox
Sun Nov 21, 2004 3:48 pm » Post: #1 » Download Post
Is there anyways that the stock airbox can be improved
Guest
Sun Nov 21, 2004 7:29 pm » Post: #2 » Download Post
Remove the lid!
Mon Nov 22, 2004 8:17 am » Post: #3 » Download Post
Amongst other things.
Removing the lid is pretty extreme, and you'll probably bugger the mid range fuelling. A better bet is to make the intake holes bigger - I sawed off the two small holes and made it into one large one.
Others drill several large holes in the top and sides of the lid.
You can also take a blade to the insides and remove the web that splits the box in two - effectively doubling the size of the box.
Most extreme is to remove it altogether, but this is not ideal for road use as the motor will be very peaky.
Jeff SZ
Tue Nov 23, 2004 12:46 am » Post: #4 » Download Post
I have the same set-up as Dave, work well for street use.
salopbike
1989 Honda NSR250 MC18
Tue Nov 23, 2004 11:42 am » Post: #5 » Download Post
i cut the 2 intake holes out and put some mesh over the gap took the filter out and it buggerd the mid range up comptetely, but it was olton park and it was 1 degree above zero so i think i was expecting too much, what jetting would any one recomend for :-
std mc18 r5
wire splice
mod air box (as above but with webs cut out)
tyga gp pipes
tyga reed blocks
carbon reeds
"cant you see the no smoking sign, this is a public space" rrrrrrriiiiinnnnngggggg ddddddiiiiinnnnnnggggggg 2 stroke till i die
Wed Nov 24, 2004 9:53 am » Post: #6 » Download Post
Oof!
No-one really likes to put jetting figures, as they vary so wildly.
When I was racing mine, I had no filter, TYGA pipes, reeds and stuffers, HRC jet kit and ignition unit, and was running between 180 and 200 depending on the weather...
