First start
j911brick
First start
Mon Apr 23, 2007 5:34 pm » Post: #1 » Download Post
Well, I got the NSR fired up and everything seems fine and sounds good.
Seems to be a bit rich on the 30:1 premix. The oil pump just barely dribbles out at idle (and I do mean barely), then it dribbles more when I open the servo. Does this sound right?
The oil light went off.
RC valves seem to go back and forth when I rev it.
Temp seems OK.
Does everything sound like its in order? Any other advice before I button it up? I guess I need to sync the carbs.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Fri Apr 27, 2007 7:51 am » Post: #2 » Download Post
Sounds about right from the oil pump.
Can't recall what work's been done, but remember the heat cycles if there's new pistons / replates etc.
Otherwise, all appears good, so carry on as if yer normal! Wink
j911brick
Fri Apr 27, 2007 8:04 am » Post: #3 » Download Post
Thanks Dave.
Turns out I was way over jetted. I used the reccomended HRC settings, then went to the smallest jets in the HRC kit, then I put the stock jets back in which works the best. Makes sense since I'm still running the stock pipes. Still can't ride it though - waiting on a sprocket shaft seal. I'm told Honda JP went on Holidy and won't be back for two more weeks, which means three weeks at least to get the seal. Then I have to figure out how to get it registered.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
