taking forks apart
malc
taking forks apart
Sat Jul 21, 2007 3:19 pm » Post: #1 » Download Post
Hi, I am trying to seperate my fork slider from the alloy body ,got the spring and all the damper rod out as well as the oil seal clip. now the fun bit Confused is it a case giving giving a good tug on the slider to pop the seal out or do i need to go into the slider and undo the castlated nut(that requires me to make a special tool to undo) i can see on the inside of the slider before it will come apart. this is a bog standard mc21r fork with no rebound or comp damping Sad many thanks hope you can make sense of this post
cheers Malc
stone chips are the real trophies
Sat Jul 21, 2007 3:54 pm » Post: #2 » Download Post
StephenRC45 is your man for questions about pulling apart front suspension... he loves it! I'm sure he'll be along soon! (Work kicks him out about 5pm on a Saturday!) Smile
Sat Jul 21, 2007 5:10 pm » Post: #3 » Download Post
Take a look at this:
http://www.dreamgate.ne.jp/nsr/technical/mc28SE_forks.html
If you have removed the dust seal, circlip, damper rod and allen bolt at the fork bottom it just needs a good hard tug to break the seal and bush free.
mick
Sat Jul 21, 2007 6:20 pm » Post: #4 » Download Post
No No No. dont use a vice it can deform the tube.
Simply clamp the forks back in the yokes and use the bottom of the fork as slide hammer.
malc
Sun Jul 22, 2007 7:45 am » Post: #5 » Download Post
Many thanks for that guys didnt want to be brutal and do damage
cheers Malc
