Yes, you cna fit any of the other model's ign's but you will also need to change the fly wheels and pick ups.
However the RS and early F3's also used the mc16-ish style ign so there isnt much wrong with it. _________________ If I have to take the carbs off once more...
But they are based on the same ideas using an RC valve controler etc etc.
HRC made 2 types of race ign for the '16 the first one used the stock cdi's with a HRC RC valve controller and an F3 harness (I have one of them for sale). The second type used a fully HRC system that didnt use the twin CDI's which is closer still to an RS.
You can't fit RS ign though to a stock 16 as you need the F3 crank cases. _________________ If I have to take the carbs off once more...
All this souds quite complicated, the reason for the inital question was i am finding it extremely difficult to find an stock MC16 CDI. thanks for the response.Brian
i have been really struggling to find a replacement cdi for one that is u/s, however i think someone from the site has come up with one, I was trying to think ahead just in case i couldn't find one, of some viable alternative. Thanks for the feedback. B
