help
owo1
help
Sat Aug 04, 2007 9:19 am » Post: #1 » Download Post
hi help need to know , ive removed the water/oil pump drive shaft.
as the shaft had pitted where the seal sits, and the plastic drive wheel
has cracks . while waiting for a new one . two stroke oil is leaking from
the oil pump drive hole in the side casing. into where gear oil will be.
are there eny seals at the oil pump i should replace ! . is this ok
have new drive waiting to fit . mc18sp many thanks Crying or Very sad
owo1
Sun Aug 05, 2007 10:43 am » Post: #2 » Download Post
eny advice please !
owo1
Thu Aug 09, 2007 6:20 pm » Post: #3 » Download Post
is it best to take off the oil pump ?
j911brick
Fri Aug 10, 2007 2:47 pm » Post: #4 » Download Post
I can't believe you can't get any help on this. Perhaps they don't understand the question and you should rephrase it.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
cgallant
2001 Honda RS250
Fri Aug 10, 2007 3:25 pm » Post: #5 » Download Post
remove the oil pump setup, go with pre-mix and put it back together when you get the new shaft/seals.
THe only think you need to do it build a blocking plate/gasket to block off the hole where the oil pump goes, and then block off the two nipples on the carb insulators/intake where the oil lines connect to.
Mix at 32:1 and you shoudl be okay
Charles Gallant
owo1
Fri Aug 10, 2007 6:02 pm » Post: #6 » Download Post
thanks but i will take pump out for a look . the oil is draing through the
pump and simpely coming through open hole for water pump drive .
stil it means the gear box will be always toped up Crying or Very sad
alannsr250
    Send private message View user's profile Send e-mail Visit poster's website MSN Messenger
Sat Aug 11, 2007 2:12 pm » Post: #7 » Download Post
do you want to buy my number plate? ends in owo Razz
Honda nc23 CBR400 AERO 1986, 1990 honda NC23 Tri-Arm, 1987VFR400 NC24 Rothmans Rep, NSR250 MC16 1987, CL250s 1983. Moto guzzi zigolo 110cc 1958. Fantic 50cc 1972. Suzuki Cobra Race bike 500cc 2t 1975 , GP125 1975. Triumph T110 1954. BSA Thunderbird 1955. Ariel VB 600 1952, 1990 MuZ 125 etz.
