HELP NEEDED
caz1969
HELP NEEDED
Sun Sep 23, 2007 9:58 pm » Post: #1 » Download Post
Hi can any-one help i have a mc16 which is only running on the front cylinder i have checked the coils and they are both working i'm not sure of what to look at next carbs have been cleaned out so i hope some-one out there can help me please HI THANKS TO EVERY-ONE FOR THE ADVICE IT'S NOW RUNNING ON BOTH CYLINDERS ALL I DONE WAS CLEAN BOTH PULSERS AND THE PLUG WHERE THE PROBLEM WAS ALL I GOT TO DO NOW IS TRY TO SET THE MIXTURE AND OIL PUMP AS IT SEEMS TO BE RUNNING RICH THEN BALANCE THE CARBS.
Mon Sep 24, 2007 12:25 am » Post: #2 » Download Post
Try a Forum search. There has been a lot of topics regarding this lately.
j911brick
Mon Sep 24, 2007 1:25 am » Post: #3 » Download Post
Check compression.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
mach1
Mon Sep 24, 2007 3:59 pm » Post: #4 » Download Post
check CDI units, try swoping them and see if the other cylinder fires up. if it does get another CDI to replace the U/S item. B
beakergixer750cc
Mon Sep 24, 2007 6:05 pm » Post: #5 » Download Post
pm me your address mate and i'll pop over at the weekend and have a look for you if you want,and i got a spare cdi unit if you need it.
cheers Rob
Inthe80s
damn i've got the same problem
Mon Sep 24, 2007 7:20 pm » Post: #6 » Download Post
my front cylinder started missing fristly after a really long ride out, then intermittently, then it just stopped and wouldn't kick back in.
i checked the fuel getting to the cylinder(okay), the spark plug (okay) and then swapped over the coils (okay).
the strange thing is the only problem only happens when it gets warm as from cold the problem goes away but 5 miles into the journey it dies on the front. i'm thinking the coil but now i've read this i'm going to consider the cdi unit. i had a dodgy cdi on a kmx once and it seemed the same but before i spend out, i want to check the coil independently first once i've worked out how to do it.
i might check the wires around the cdi unit cos since having the bike i have taken the rear section off of my mc16 and since the previous owner made it one piece and it is a bit awkward to get off and on, i might have trapped something and it might be earthing out.
please let me know how you get on.
thanks
