MC16 troubles
mach1
MC16 troubles
Fri Oct 05, 2007 8:06 pm » Post: #1 » Download Post
Hi all, continuing with the rebuild of my mc16 today i got her started up, after a few minutes warm up i started to rev the bike. it back fired a couple of times then stopped. checked the fuel o.k. checked all the fuses in the fuse box o.k.
Are there any other fuses anywhere that might stop the engine firing? i've checked for a spark but there is'nt one.The nuetral light on the dash does'nt light up anymore is this just a coincidence or is it related to the problem. Just when things seemed to be going so well!!any help much appreciated.Brian
mach1
Sat Oct 06, 2007 11:27 am » Post: #2 » Download Post
Any clues anyone? Please!!
howl
Sat Oct 06, 2007 12:25 pm » Post: #3 » Download Post
Hi Brian
Has the 16 got a side stand switch ? If so ,you might want to move the gear lever to get the neutral light on again as tha bike will not run in gear or with out the light on with the side stand down.Or just run try it with the stand up.
If they don't have a side stand switch then ignore my ramblings.
mach1
Sat Oct 06, 2007 12:43 pm » Post: #4 » Download Post
Hi thanks, the bike is in nuetral i have checked it (rocked it ect..) i have had it started with the side stand down already. Still it's all good stuff, lets hope we can work through the problem cos i'm useless at electrics. once agaian thanks for the reply. Brian
beakergixer750cc
Sat Oct 06, 2007 1:44 pm » Post: #5 » Download Post
check if you still have a spark at the plug mate
howl
Sat Oct 06, 2007 4:31 pm » Post: #6 » Download Post
Brian you didn't say if the 16 has a side stand switch .
mach1
Sat Oct 06, 2007 4:31 pm » Post: #7 » Download Post
Relax men!!after fumbling around it was a loose connection from the stator to the wiring loom, Phew thank god for that, i hate a electrical gremlins. She's got the carbon cans on from swarbrick racing onto the standard expansion chambers, what a lovely sound. Once again thanks men, you give me the confidence to carry on. Brian
Inthe80s
lets see those cans
Sun Oct 07, 2007 2:02 pm » Post: #8 » Download Post
have you got a picture of the cans and how much did they cost? let me know if you notice any difference or improvements in the performance.
mach1
Sun Oct 07, 2007 3:39 pm » Post: #9 » Download Post
Yea i'll let you know how they run, could be a while yet got quite a bit of work to do yet. if i can i'll put some photos on, however i'm not very good at doing that sort of thing but i'l give it a go, cheers Brian
