The front pot oils up if let idling too long when cold. Generally the front cylinder doesn't run cleanly up to 3.5K then everything smooths out. No problem at the top end and will rev through to 11.5K no problem
The list of things tried so far;
top end (replate etc)
new coils
new pickups
cleaned carbs and jets air-lined
tried an iridium plug, which worked ok for a couple of weeks
switched to super plus fuel
adjusted the idle to 1200 when warm
just cleaned every contact, but haven't put in new plugs yet
I did notice stands of wire collect on the pickups when they were replaced. I guess the only place the could have come from is the generator windings. I haven't checked again recently.
Since adjusting the idle the bike fires 1st kick, idles at 3-4K revs then settles to 1200
I did take the bike up to Gibsons in the summer for them to look at, but no success. The carbs were taken off & cleaned, but not re-balanced
